i just got my 331 running. everything is new- motorsport flywheel, romac balancer, clutch. it vibrates pretty bad when it hits about 2000 rpm. its the eagle 331 with srp pistons.
they said it was an internally balanced motor, so i got the 0 balance flywheel and balancer, i started it up and it was horribly vibrating. then i found out from eagle that its an externally balanced motor and i need the 28oz flywheel and balancer. so i finally got it all done and it still vibrates. i am going to KILL SOMEONE!!!
does anybody know whats going on?
thanks in advance
check out this link here to check out everything i got
http://www.cardomain.com/id/86stang
thanks in advance
