I just finished my AOD to 5spd swap & I'm getting a really bad vibration above 2k and ONLY in 5th gear. It also only happens when I'm decelerating in 5th gear. I've taken it up to about 3k in 5th with no vibration, but as soon as I let off, all hell breaks loose. It also sounds like vibrating metal, like my exhaust is rubbing something, but it's not. And the metal noise is only in 5th as well.
I did a little test and took my car up to 4500k in 4th, no vibration. I shifted into 5th, went to 2500k & let off, crazy vibrations
I can take it to any RPM in any gear, except 5th, let off the gas & have no vibrations. PLEASE help because I'm ready to drive off a cliff
(even though they don't exsist where I live)
Let me tell you, despite all the problems I'm having, it pulls so much harder in 2nd and 3rd than the stock AOD ever did. It's like a completely different car. Just make sure you drain the AOD before you drop it & have a prybar available to pry that beast from the block. Below is what happens when you don't drain it
