You need to give more details.
Car moving or not?
If it's moving, does it happen in gear and out of gear coasting?
Things that usually cause vibration:
Tire balancing
Bad alignment
Bad U joints
Unbalanced driveshaft
balancer (usually pretty violent when a balancer goes)
worn out flywheel
Use common sense when trying to figure it out.
For example, you know it can't be the driveshaft if the car is not moving.
