violent shake when taking off
notny41
204
Minnesota
I have a 1965 fastback with 289 4v 4speed manual with manual steer. Every once in a while when I turn left (at least that's when I have noticed it recently), when I take off real slow and don't rev the engine up enough my car goes into a violent shake until I push the clutch in again and rev a little higher and let it back out.
Anyone else experiencing this?
Thanks - P
Or motor mounts. With the engine idling rev the engine hard a couple time. If you have a bad motor mount the engine will torque over toward the passenger side. The drivers side will lift up a little. The drivers side mount is bad. To fix, you could install a torque strap.
naw,i put my money on a clutch.Mine is doing the same thing now and I know theres hot spots and worn clutch,plus I have new mounts. :(
yep, I have new mounts too and a torque strap so I'd bet it is the clutch too. I'm not so ambitious as to drop the tranny though. Think I'll just keep driving it for a dang long time before I end up having clutch work done.
Thanks guys!
P
Thanks guys!
P
just do what I do,when you feel it start to jump,push it back in then slip it so you dont embarass yourself.Its fine if you want to launch it off the line. :rolleyes:
My 65 did this before also. And one day while driving to work there was a loud boom noise from the tranny tunnel. I got it to work and home at about 10 mph but could not get up my driveway which has a slight hill. When I pulled the bellhousing off black burnt pieces of my pressure plate fell out. . .Replaced clutch with a kit since and now is fine.
