Vortech install questions.
95 stanger
17
Missouri
I am installing an S trim on my car. The motor is stock except for a Performer intake, BBK throttle body, headers and exhaust. I decided to install 42lbs. injectors and 90mm Lightning MAF along with the Vortech. My questions are: I will not need the FMU, correct? Should I use the T-Rex pump along with the stock pump or is it better to go ahead and replace the in tank pump? Thanks for your help!
you will need the fmu unless you get a custom tune or a programmer of some sort, I would upgrade your tank pump to at least a 190 but for the extra couple of bucks get the255 youdont wanna cheese out on the fuel thats how you can blow stuff up
Hi
I have 42#'s with a 225 in tank and using the t-rex in line, and no fmu, custom tune. As said before you should be fine. Use the fmu if you don't custom tune , (which I don't suggest) get it tuned. Well I just reread what you posted you must have a custom tune with the Lightning maf get it retuned!!:)
