  • SN95 4.6L Mustang Tech
Vortech Questions
  • Thread starter Thread starter J smitty
  • Start date Start date Oct 26, 2008
J
J smitty
32
Foristell Mo
Oct 26, 2008
  • Oct 26, 2008
So my vortech is installed everything went great but there were a few questions..
Where does the bypass valve end (the end the small hose goes on) connect to the vaccume line? Like where does the hose and 3 way connector go? Also it talks of an ignition capatictor relocation. Yea don't know what that is.
So the initial start up was great but i heard a knocking noise, but it was just a belt not all the way on the powersteering. But now when im in boost there is a clicking noise. It doesent sound likedetonation but like if i take it to redline slow it doesnt happen but when i am gettin at it and take it to red like there is a slight almost like something is wiggling against something from vibratino.
Stark77
501
Tallahassee, FL
Oct 26, 2008
  • Oct 26, 2008
valve chatter? noisy lifters?
J
J smitty
32
Foristell Mo
Oct 26, 2008
  • Oct 26, 2008
well i can lift up the hood and rev it up and nothing. DO you think a good dyno guy could tell me?
T
TropicMustang
77
Concord
Oct 26, 2008
  • Oct 26, 2008
The small tube on the bypass valve tees into the TPS wire. Its the red wire near the throttle body. You really dont have to worry about moving the capacitor. I just lossened mine and rotated it some.
J
J smitty
32
Foristell Mo
Oct 27, 2008
  • Oct 27, 2008
OK I see the red wire connecting into the plenum. Its like where two wires meet. But where should i put the t and connection? I found where the hose leads to infront of the passenger firewall. Is that where it goes?
D
darkside03gt
851
Sacramento CA
Oct 27, 2008
  • Oct 27, 2008
that sounds like you have mild detonation. your either not getting enought fuel, your timing is off or the ecu isnt calculating the load correctly. in shot GET IT TUNED!!!!
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Oct 27, 2008
  • Oct 27, 2008
Definately get that beast tuned before it chuck the dueces on ya. I'd hate to see a fellow stangbangers chit go up in smoke. Did your kit not come with a tuner with a tune for the SC?
J
J smitty
32
Foristell Mo
Oct 28, 2008
  • Oct 28, 2008
The kit came with the MPH tune. I got it dyno'ed today 357/355 and they added fuel because it was leaning out up top. But I guess the rattle must just be the lower loose fenderwell or something like that because on the dyno she screamed like a whore.
J
J smitty
32
Foristell Mo
Oct 29, 2008
  • Oct 29, 2008
Does anyone have any pictures on how to route the t fitting into the vaccume line? And if I were routing a boost gauge could I get a 4way cross fitting and run the boost gauge hose line here?
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
A
Strange AC issue
  • Adanesahde
  • May 3, 2025
SN95 4.6L Mustang Tech May 3, 2025
Mcmahst
