Vortech SC 5psi VS AFR H/C/I
well i cant decided between the kit you see below from Ed Curtis or just going with the 5psi vortech kit. heres what i lookes like price wise....
AFR 165 emission heads: $1325
Valve Spring Upgrade: $125
Viton Seal Upgrade: $32
ARP 7/16 Rocker Studs: $25
Custom Camshaft: $325
Scorpion 1.60 Roller Rockers: $200
Billet Roller Timing Set: have
Misc.:
Head Gaskets: have
Intake Gasket: have
Timing Set Gasket: $15
Eaton Lifters: have
Hardened Push Rods: $112
ARP Head Bolts: have
then UPS shipping : 100 bucks as a low guess
so that ends up costing me about $2259 as a rough estimate.
then on the other hand if i went with the Vortech V-1 sc-trim with 5 psi i could pick that up for anywhere around 1600-1800 dollars. for those of you with the 5 psi do you guys have any dyno numbers on a stock short block, would it help alot to port my heads? also should i keep my edelbrock performer intake or will it not help that much. I need opinions quick because i need to get my car back together. which one would make more power? be more dependable? all that kinda stuff. thanks guys
Misc.:
Head Gaskets: have
Intake Gasket: have
Eaton Lifters: have
The choice is yours and yours alone.
We both are named David and we both have green stangs, and I have a 2000 Ranger as a daily driver and you said you wanted one. We also had the same decision to make. I went with the blower, becuase anything you add down the line will give big gains.
...that 190 will do ya just fine though...
