  • 1994 - 1995 Specific Tech
vortech supercharger and vert????
  • Thread starter Thread starter slayerripkdc
  • Start date Start date Oct 3, 2006
slayerripkdc
1,341
brewster ny
Oct 3, 2006
  • Oct 3, 2006
Is a 95 vert capable of running 12's with the V-2 SQ S-Trim??????? Also what would it put down to the wheels????? Will i need any other mods to the engine, or i can just bolt on the kit then hammer it My motor has 115k and was wondering if it will handle the supercharger and be fine?
AznStanger3v
2,026
Northern VA
Oct 3, 2006
  • Oct 3, 2006
itll run 12s.
cant say on the hp numbers
itll take it, but not for too long.
youll need fuel upgrades big time.
ProKiller
3,064
15
78
PA
Oct 4, 2006
  • Oct 4, 2006
buy a complete kit and have it professional tuned. you should be fine for a while as long as you don't go crazy with the boost.
The B-cam you have isn't that good for power adders though. you might want to look into a different cam.
i don't think it will run 12s, most likely 13s. if i had to guess about your hp then i would have to say around 300rwhp.
Wi Stang
248
Fountain City, WI
Oct 4, 2006
  • Oct 4, 2006
I think it would run 12's with good traction. I am not sure about hp at the wheels. On the Vortech website it says you will pick up 104 hp, and 84 ftlbs. I imagine that is at the crank.
I would upgrade the fuel pump to a 255 lph, larger injectors, and matched mass air meter to the size of the injectors. The other thing would be to get it dyno tuned right after putting it on.
Getting a good tune is probably the most important thing to help the motor last.
pwcracer
347
Hastings, MN, USA
Oct 4, 2006
  • Oct 4, 2006
That was my goal but went with the KB. KB told me to just bolt on the kit, but I ended up doing most the mods in my sig due to the SC.. Now as of late, my clutch is starting to slip as well... More upgrades
I also heard that you can't run faster than 13 at a track unless you get a roll cage (for converts)
Black Stampede
1,811
Grand Rapids, MI
Oct 4, 2006
  • Oct 4, 2006
I believe the roll bar cut off is 13.5 for verts. If it doesn't run 12s then you can't drive or you need better tires. I think those kits on fairly stock cars put down around 320 rwhp.
Stanger007
2,015
Baton Rouge, LA
Nov 12, 2006
  • Nov 12, 2006
Rollbar cutoff for convertibles at the two tracks by my house is 12.99.
Bump for more info on 'verts w/ S-trims... mine comes in next week.
HGFireHazard
460
Michigan
Nov 12, 2006
  • Nov 12, 2006
I make 313 rw on the stock longblock. I've seen less go deep 12s on good tires and would imagine you could do the same.
droptopford 5 0
427
Nov 14, 2006
  • Nov 14, 2006
i posted a similar question about my full weight 94 vert hitting 12's with just a trickflow h/c/i and possibly d/r's... i was basically told that i should sell my car to someone who can drive if i dont touch high 12's with it... plus you'll be making much more tq than me, you have 4.10's instead of just 3.73's and will have a good 25 hp more than me. you'll do it easy. then killercanary made me look bad by throwing out his full weight numbers of 12.3's with a similar setup
Black Stampede
1,811
Grand Rapids, MI
Nov 15, 2006
#10
  • Nov 15, 2006
  • #10
Just get a turbo and run 11s.
Supercharger and What else do I need? 1990 Saleen Vert 5spd
  • AlbertaGolfer68
  • Aug 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
General karthief
9
WTB: Procharger or Vortech Supercharger – 1996–1998 Mustang GT 4.6 2V – Budget $3,200
  • 96mustang.gt
  • Nov 20, 2025
  • Want to Buy
Want to Buy May 3, 2026
roblabsn95
R
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Fuel Vortech Supercharger injectors
  • Dontknowchit
  • Mar 13, 2025
Fox 5.0 Mustang Tech Mar 8, 2026
from6to8
