Vortech Supercharger???
  • Thread starter Thread starter $uperstang
  • Start date Start date Nov 23, 2005
$uperstang
476
Detroit, MI
Nov 23, 2005
  • Nov 23, 2005
HI guys,
I was planning on getting a Vortech Supercharger, just a small one like the SC-Trim because I just want about 5-6psi of boost on this bad boy. I was wondering if I did get one would I have to get bigger injectors and a T-Rex pump as well? Or will my current set-up support the SC trim, not sure if it comes with an FMU though or if I will need one?
What do you guys think?
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Nov 23, 2005
  • Nov 23, 2005
Your 255lph in-tank pump will be fine. You won't need the t-rex inline. However, those 24lbers aren't gonna get the job done. You'd need at least 30's. If you buy a complete kit, it will come with an fmu but i'm not a fan of them. If you want to do it right, get bigger injectors and a calibrated MAF to match.
$uperstang
476
Detroit, MI
Nov 23, 2005
  • Nov 23, 2005
If I upped the injectors to 30-36 and sent my Pro-M meter back to get it calibrated then that is it for the set-up and I will not need the FMU? I am thinking 36lb injectors then?
I
IntenseBlue
946
  • Nov 23, 2005
Correct.
RacEoHolic330
4,014
1,698
203
Allentown, PA
Nov 23, 2005
  • Nov 23, 2005
yeah. for 6lbs of boost, 36's would work well with the 255 inline pump.
Kabuki_notch
670
394
113
Rochester, NY
Nov 23, 2005
  • Nov 23, 2005
I run 30lbers with 255lph in-tank, If you buy the kit it comes with the FMU and you can just buy calibration disc's to calibrate it
Paul Perreca
1,085
  • Nov 23, 2005
i don't see how ppl can say you save gas w/ a supercharger, if you have to put such big injectors on there - they say you will gain MPG daily driving w/ ur foot out of the throttle, but it sucks it down whne you gun it
QDRHRSE
1,590
Palmdale, CA
Nov 23, 2005
  • Nov 23, 2005
I run 12lbs of boost with 36's and a 255lph intank pump. I had a BBK pump, same as a TRex, and I didn't need it. I still have it in a box. I do, however, have a rising rate, or boost sensitive, fp regulator that gives the engine an extra lb of fp for every lb of boost....just to be safe.
L
luckythirteen13
648
Anaheim, CA
Nov 23, 2005
  • Nov 23, 2005
youd still want a dayno tune after the install even if you get big enough injectors because the stock fuel reg. wont increase pressure with boost, at 0vac you get all the fuel pressure it can give you
$uperstang
476
Detroit, MI
Nov 28, 2005
#10
  • Nov 28, 2005
  • #10
Thanks guys for the help!
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
Fuel Vortech Supercharger injectors
  • Dontknowchit
  • Mar 13, 2025
2K
Fox 5.0 Mustang Tech Mar 8, 2026
from6to8
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
  • brandyn200
  • Jun 20, 2026
AeroCoupe
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
