  • 1994 - 1995 Specific Tech
VSS Removal
  • Thread starter Thread starter krahkin
  • Start date Start date May 23, 2005
krahkin
183
Acworth GA
May 23, 2005
  • May 23, 2005
Has anyone with a 94/95 Mustang removed the VSS signal to the ECU? I wanted to know if it worked, and where you disconnected (at the ECU or at the sensor). I am tired of the hanging idle between shifts and want to eliminate this problem. I know a fox can do this, but Ive never seen/heard of an SN running w/o their VSS.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
May 23, 2005
  • May 23, 2005
VSS as in vehicle speed sensor, if so with it disconected how would you tell how fast your going?????
krahkin
183
Acworth GA
May 23, 2005
  • May 23, 2005
Im not sure how it is routed. I 'thought' that the signal to the ecu and the signal to the speedometer were seperate.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
May 23, 2005
  • May 23, 2005
Do a search on "hanging idle" in this section. All you need to do is reset your idle properly, and keep the IAC valve screw to less then 2 turns, and your hanging idle will go away.
Scott
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
  • Gulftown980x
  • Jul 29, 2026
squeak93
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
