Nice gains!! I'm running the same cams and love them. I gained 19rwhp & 23rwt over my power heads stage 1 regrind cams.
Those are some nice times in your signature. Can you tell me a little bit about your set up? Rear-end? Suspension? Rims & tires? Trans?
No problem, here's everything.
Motor
CMS Stage II N/A cams w/ Manley springs
TrickFlow ported upper plenum
BBK 75mm TB
NX EFI Kit
NX/MSD window switch
SVT Focus fuel pump
Speedy Dyno Tune (SCT Flasher) N/A & N2O tunes
180* T-stat
Steeda Pullies
9"K&N w/ no airbox
Denscharger MAF to TB only
Flowtech Longtubes
MAC o/r x-pipe
Spintech Pro Streets w/ tails
Hawker Battery
Energy Poly Motor Mounts
Drivetrain:
FRPP 4.10's
UPR shifter
King Cobra clutch w kevlar disc
Fidanza Al. flywheel
Axle tubes welded
Detriot True Trac
UPR Girdle
Moser Axles
FRPP Alum. Driveshaft
UPR Driveshaft Safety Loop
Suspension:
Fox-body 4cyl springs(NAPA #270-3060) up front w/ Lakewood 90/10 struts
Fox-body V8 rear springs (cut)
KYB AGX adjustable rear shocks
Airbag in RR spring
No front swaybar
No rear swaybar
UPR sub-frame connectors
UPR Pro Series Lower Control Arms, solid/spherical ends
UPR Pro Series adjustable uppers, spherical ends
Jegs Poly axle bushings
Torque boxes welded
No quad shocks
Wheels/tires
Front - 165x15 on 15x4 Centerline Telstars
Rear - 26x11.5x15 Hoosier QTP's on 15x8w/5"bs Centerline Telstars
Body/ misc
Grill delete
Mach 1 chin spoiler
Steeda 3" Cobra R hood
