walbro 255 inline pump install
  • Thread starter Thread starter HuebyStang94
  • Start date Start date Apr 12, 2005
HuebyStang94
133
STL
Apr 12, 2005
  • Apr 12, 2005
Hi all, just got my Walbro 255 inline pump to put on my 94 5.0. The instructions just talk about "replacing it with the other pump" and it just has the brackets and some fittings.
Soo... how am I suppose to install it? Do i need some type of installation kit, or do I they expect you to go buy fuel line, connectors, etc. and rig something up? Thanks for any info.....
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Apr 12, 2005
  • Apr 12, 2005
Edited...sorry...wrong info
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Apr 13, 2005
  • Apr 13, 2005
in line, not in tank.
just follow the instructions. its easy only seems hard.
1990LXDropTop
430
Western Massachusetts
Apr 13, 2005
  • Apr 13, 2005
I just swapped out my stocker for a walbro 255lph pump last week. It took about an hour. The hardest part is dropping the tank. After that it's cake. Just make sure you are low on gas before attempting to drop the tank. FOLLOW THE INSTRUCTIONS.
HuebyStang94
133
STL
Apr 13, 2005
  • Apr 13, 2005
I've already done the INTAKE install.. i'm talking about the INLINE pump. Like the T-Rex.. but this INLINE walbro 255 instructions just say to "replace the other pump", which we do not have an inline pump to "swap" out.
SO it looks like I need to fabricate something up, no? thanks!
O
OneBad93Z
200
Cocoa/Titusville, Fl
Apr 13, 2005
  • Apr 13, 2005
Is your tank sumped?
HuebyStang94
133
STL
Apr 13, 2005
  • Apr 13, 2005
No, stock tank, stock lines... only mod is INTANK walbro 255.
Just looking on summit.. it looks like i needed a kit like this with all the installation parts too....
http://store.summitracing.com/default.asp?target=partdetail.asp&Ntt=inline+fuel+pump&N=0&Nao=0&part=VOR%2D8F201%2D265&autoview=sku&Ntk=KeywordSearch
HuebyStang94
133
STL
Apr 14, 2005
  • Apr 14, 2005
Okay well talked to some people and they just said to go to the parts store and buy the fuel line. Connect the new line from the fitting at the top of the tank to this pump, and the connect the new line from this pump to the inlet on the filter. To use 10ga wire, and/or you can run a relay of the factory pumps wire.
Anyone have any comments on this suggestion? Should I run some seperate wire back for the pump, or use a relay to power it?
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
A
Resolved Fuel pressure high at 52 new FPR same thing
  • afjLX
  • Dec 28, 2024
  • 3 4 5
5K
Fox 5.0 Mustang Tech Jan 11, 2025
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
J
Fuel pump question
  • jay99914
  • Feb 24, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 5, 2025
89ripper
A
Procharger install/prep questions
  • ahratrew
  • Nov 22, 2025
SN95 4.6L Mustang Tech Nov 26, 2025
