Want to drop 1 tenth from my 60'
sporadic
71
WV
Current best 60' is 1.71, launching at redline and slipping the clutch.
If I don't slip the clutch I'll sping and end up with a 1.8xx 60'.
I run 26x10.5/15 ET Streets at ~10psi.
4.56 gears, rest of mods are in sig.
I want to be able to dump the clutch and not spin.
I know I need a lot of front suspension work, so I'm looking for more advice.
I want to stay under $1,000 and the further the better!
Things I've certainly decided on: full length subframes and lighter battery.
Setups to consider:
A:
QA1 Full Tubular Front incl 12 way adj struts $1000
Stock rear
-60+ lbs
B:
AJE K Member uses stock struts/springs LMM 329
Front Struts Strange 222
Drag Springs front & rear Steeda 210
Drag shocks rear 200
-30+ lbs
total $961
C:
4 cyl Fox springs used 30
Stock rear
-30+ lbs
total $581
D:
AJE K Member + A arms uses stock struts/springs QA1 (REDLINE RACING) corral.net 425
Stock rear
-50+ lbs
total: $677
All other setup suggestions welcomed!
Does anyone use Strange 10-way adjustable struts?
They look like an awesome deal at $111 each.
For drag racing, what does going to coil-overs up front accomplish?
Thanks! :nice:
Well, dont know if this would help as much as you want, but what is the traction difference in the ET street and the ET Drag. Dont know, but worth a shot. BTW Awesome car, anything that only have 4.56's and suspension work that runs a 12.6 is amazing, good work man.
Just saw that it was a Mach, but nonetheless VERY impressive.
