  • 1994 - 1995 Specific Tech
washed engine,now problems
  • Thread starter Thread starter 94GTCoupe
  • Start date Start date Nov 12, 2009
  • 3
  • 4
First Prev 3 of 4 Next Last
94GTCoupe
1,412
92
79
CA
Nov 14, 2009
#41
  • Nov 14, 2009
  • #41
could it be the pip?
iirc,when my pip was going bad before,the car would stall out and i would always get a bad fuel pump code.
was all good after i got the reman dizzy from autozone.
just thinking out loud...
BlackVert
5,589
9
98
Bethesda, MD
Nov 14, 2009
#42
  • Nov 14, 2009
  • #42
note to self: never wash your engine
dang man, sorry to hear about all this crap.
that doesn't sound like the pip, at least not to me
i'd try new hego sensors, or at least take these out and let it sit overnight so they will dry out and then put them back in.
94GTCoupe
1,412
92
79
CA
Nov 14, 2009
#43
  • Nov 14, 2009
  • #43
Posted via Mobile Device
thats what i'm sayin,never again!.
i got 1 brand new o2 in there,its been a full week with these problems.
HISSIN50
34
129
Nov 14, 2009
#44
  • Nov 14, 2009
  • #44
Time to look at that O2 signal.
94GTCoupe
1,412
92
79
CA
Nov 14, 2009
#45
  • Nov 14, 2009
  • #45
i think your right,Hissin.
got any tips on how to get it done,and what i'm looking for?
thanks.
HISSIN50
34
129
Nov 14, 2009
#46
  • Nov 14, 2009
  • #46
Look for the signal reading to go back and forth from 0.1 to 0.9 Volts quickly. I have the feeling that your O2 will either read open or will be stuck at about 0.45V (and won't have hardly any amplitude).
At the EEC, Pin 43 (red/blk) is the left HEGO.
Pin 44 (gray/lt blue) is the right HEGO (look at it for comparison if you like).
You could try to test these at the HEGO sensors themselves, but you end up sticking the wires and the HEGO wires are finicky about being punctured (special sheathing). I have not tried it yet but I kinda wanted to see if I could disconnect the connector (be sure your connectors are tight and clean inside, BTW) and get a jumper wire in there and then re-close the connector. The jumper would allow you to check voltage without messing with the wire insulation.
Anyhow, the reading should suck since you're generating a code. You'll know real quick. BTW, be sure the car is in closed loop when you check (let it idle for a few minutes before testing). O2s need to be at 600*F before their input is useful.
94GTCoupe
1,412
92
79
CA
Nov 14, 2009
#47
  • Nov 14, 2009
  • #47
thanks,Hissin.
94GTCoupe
1,412
92
79
CA
Nov 15, 2009
#48
  • Nov 15, 2009
  • #48
allright,pulled the ecm out to get to the wires,got car heating up and ready to test the o2's.
i'll report back my readings.
94GTCoupe
1,412
92
79
CA
Nov 15, 2009
#49
  • Nov 15, 2009
  • #49
hissin,would that be .1-.9,or .01-.09?
94GTCoupe
1,412
92
79
CA
Nov 15, 2009
#50
  • Nov 15, 2009
  • #50
heres my readings.
using a digital multimeter,set to 20v,ground to body.
pin 43-left o2,constant movement .01-.09,will stay at on value for a few seconds,but will move.
94GTCoupe
1,412
92
79
CA
Nov 15, 2009
#51
  • Nov 15, 2009
  • #51
pin 44-right o2,less movement,will stay on 1 value for at least 30 seconds.voltage slowly goes to 0v.
all test done with car hot idle,running for 10min before test.
94GTCoupe
1,412
92
79
CA
Nov 15, 2009
#52
  • Nov 15, 2009
  • #52
replacing right side o2.
what sucks is all day i've been driving with no problems.
HISSIN50
34
129
Nov 15, 2009
#53
  • Nov 15, 2009
  • #53
There's something wrong.
0.01 - 0.09 would be a dead O2 (reading exceptionally lean). As noted, you should have seen ~ readings from zero to almost one volt.
Since both O2s are acting up but you only spit one O2 code, there might have been an issue with the ground or the meter.
94GTCoupe
1,412
92
79
CA
Nov 15, 2009
#54
  • Nov 15, 2009
  • #54
hmm..any suggestions?
did i mention i hate electrical problems?
the only reason i washed the engine was i entered a Dyno Shootout.
i wanted it to look pretty.
hope i can get this thing running right by this saturday morning,or i can kiss my $65 goodbye.
just a recap of parts replaced,
TPS-idle was stuck at 1500rpm,tps voltage at 1.5v,could not adjust any lower.
new tps,set it to .94v
Reset Idle-reset idle with new tps,per RJ's instructions.
rock solid at 650rpm.
2 New O2 Sensors-got codes 177,172
Cleaned The Ground's-cleaned all i could find,and the pcm ground.
Added Engine To Body Ground-can never have enough.
Checked and cleaned all electrical connections in engine bay.
Checked all vacuum lines
Checked all fuses.
Wiggle Test-with car running,wiggled the poop out of all wiring.
no change in condition.
I drove around town for 10 miles.stop and go,and some long stretch's.
car ran great.
good acceleration,good idle,same power as before these stupid problems.
as of right now,car passes all tests.
koeo-111-pass,stored-111-pass
koer-pass
cylinder balance test-90-pass.
tomorrow i'll be replacing the pip at work,might aswell.
HISSIN50
34
129
Nov 15, 2009
#55
  • Nov 15, 2009
  • #55
I'd want to re-check the O2's till a good reading is acquired. It sounds like they're doing ok (and it's a testing issue) but still...............
Be sure your chosen ground for the testing is good (ohm it out if in doubt. Look for less than 5 ohms of resistance when checking for continuity-to-ground for a ground).
Either there's a wiring issue, a sensor issue, a testing issue, or the meter doesn't have enough internal resistance and is creating hysteresis.
Please give us a recap of how it's acting up and when (at this point). This thread is long enough that I'm probably missing an important post of yours wherein an issue was cleared up or changed.
94GTCoupe
1,412
92
79
CA
Nov 15, 2009
#56
  • Nov 15, 2009
  • #56
thanks Hissin,i really appreciate your help.
it's most likely me thats the problem in the testing.
i'll update if the problem shows itself again or not.
94GTCoupe
1,412
92
79
CA
Nov 16, 2009
#57
  • Nov 16, 2009
  • #57
i think its finally fixed.
so far i've driven a total of 60-65 miles so far with no problems.
i think it was a combo of problems.
1 being a bad TPS.
2 being bad O2's
Hissin,i'll check the O2 reading again this weekend.
i can borrow a better meter and make sure i have good grounds.
i'm almost positive the problem in the testing was me
and your right,i should recheck for a good reading on those O2's.
thank's everyone for your help.
hopefully this is the end of it.
:SNSign:
Adam95GT
2,564
Burlington, NJ
Nov 17, 2009
#58
  • Nov 17, 2009
  • #58
thought it was 02's
BlackVert
5,589
9
98
Bethesda, MD
Nov 17, 2009
#59
  • Nov 17, 2009
  • #59
did the light go off yet?
94GTCoupe
1,412
92
79
CA
Nov 17, 2009
#60
  • Nov 17, 2009
  • #60
you were right Adam,.
no check engine light.
i also replaced the pip yesterday.
  • 3
  • 4
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Saturday at 5:19 PM
manicmechanic007
