water/alcohol injection
water instead of gasoline!? :owned:
WTF??? Do you not understand Alky/H2O Injection or are you making a joke?
I have come up with what I consider to be the "bullet proof" alky injection system. Some people say it is too complex, but I say they are too simple minded. It will alow you to only run high boost if your injection system is working, if you loose pressure for some reason (pump fails, leak, ect.) then it will automatically switch back down to low boost to protect the engine from detonation. Or else you can just slap together a basic system that will work and cross your fingers it doesnt give out while your running 22 lbs. boost. There are lots of threads on TF.
-Josh
