water in oil
Blackened302
1,439
South TX
so after new head & intake gaskets, and ARP bolts torqued to 75lbs, there is water in my oil--after only 30 minutes of driving.
it is a white, foamy substance that's showing in the dipstick and valve cover filler.
car has been in the shop for 2 weeks and it seems that now it has to go back.
the old head gaskets were blown/leaking and the car was overheating--supposedly due to us re-using the original head bolts during the engine swap.
radiator has been flushed, along w/ the rest of teh cooling system. fans are coming on (new ccrm), 2 new thermostats, etc.
what are we doing wrong?
Dumb question: Did you drain the old oil after the new HG's were put on? Reason: The old oil prolly had water in it. I even ran a couple of gallons of kerosene through the lifter valley (with the oil drain plugs out) to rinse as much of the gunk as I could out of the pan.
heads were decked and the block was also checked w/ a straight-edge--checked out great. the oil was also drained.
just put on new intake gaskets (and siliconed the sh1t out of it) beause the old one was leaking right near the thermostat (which was also probably sticking) and cleaned up as much as we could. there is still a bit of water, but i'm hoping an oil breather (so the steam can evaporate out) and a couple oil changes will take care of the rest that's in there.
Pressure test the coolant system to 15psi and see if there is a leak. Then good luck locating it.
lower intake manifold is more likely the source rather than the heads IMO. Also, your timing cover could be the culprit. Mine was so pitted it actually had holes in it. When I pressurized the system, I could see water spraying in the distributor hole.
If it is leaking, another good way to test it is to drain the oil in both sumps, and see where the water pours out. Front sump is likely the timing cover, rear is intake/heads/block.
Scott
Scott
welp, just changed the oil and happy to report there was very little water in it, and it was no longer a frosty, white substance anymore. i understand it will take a few more oil changes for it to clear itself out, but i can only hope this is the end of this problem.
on another note: should the upper radiator hose be firm (ie, pressurized slightly)? it doesn't seem like there is too much pressure building up, but i do'nt know how firm is normal.
yup, sure should
mine is normally pretty firm.
On the coolant system pressure test: You can get a kit and it should let you know how to do it. Basically you're just pumping air through a custom radiator cap and it measures the pressure (you wanna go to your cap's rating...which is 16 iirc). Then you wanna see if the pressure drops off any substantial amount. If it does...then you have a leak, you'll also prolly hear/see it.
good luck
forgot to mention that i am not running a thermostat.
i know it's ideal to put one in, but i've had such bad luck w/ the car lately, i don't want to change anything now that's it driveable.
any cons to not running a thermostat? the coolant temp only gets to the "N" before the low-speed fan comes on and cools it back down to just under the N (via the tweecer).
Can you run it? sure
would I? Nope
I would think that the main con would be the engine not getting up to temp very quick...which would result in poor fuel economy.
I don't know how true this statement is...but...I've heard some people say that since the coolant is constantly running through your radiator..it won't have time to actually dissipate the heat and you could start to run hot (from what you're saying this isn't a problem though)
It's a really cheap part and I don't think it'd do much damage if you installed a 180 degree thermostat. I've always drilled a small hole in mine just in case it happens to close up.
also, see what you can do to get an aftermarket water temp gauge.
hope I helped some
perhaps i've had bad luck w/ the thermostats (160*) because i've been using cheap ones from Advance.
can anyone recommend a good 160-180* thermostat that won't give out as quickly as the Advance ones? a Mr. Gasket, perhaps?
an aftermarket temp gauage is definately on the list!
