Interior and Upholstery Water leak, passenger side, ripped seats and carpet out already.
  • Thread starter Thread starter 2000ElectricGreen
  • Start date Start date Mar 18, 2026
  • Tags Tags
    2000 new edge sn95
2000ElectricGreen
Nanaimo, British Columbia, Canada
Mar 18, 2026
  • Mar 18, 2026
Hey folks,
any one got a good video of a 2000 / new edge mustang having the front cowl taken off and cleaned out?
I got a passenger side water leak, pretty sure condenser is clogged as no water exiting its lil spout noodle bit on the firewall
However i can't find a single video that actually shows me how to unclog the passenger side under the cowling.
it appears only on the passenger side there is an extra layer of metal shielding(?)
how should i get under this to unclog?
squeak93
2,315
391
164
Joplin, Missouri
Mar 23, 2026
  • Mar 23, 2026
Is it water or coolant? Heater cores usually drain outside if leaking but that drain can clog and then back up into the interior (More comon on a fox vs sn but still happens). You'll need to verify but sounds like a heater core or at least dash removal is in the cards.
2000ElectricGreen
Mar 24, 2026
  • Mar 24, 2026
squeak93 said:
Is it water or coolant? Heater cores usually drain outside if leaking but that drain can clog and then back up into the interior (More coming on a fox vs sn but still happens). You'll need to verify but sounds like a heater core or at least dash removal is in the cards.
Fuuuuuuuuu
you responded to my other post, same goes, I’m going to weather test that heater drain as you suggested to pay attention to. However I suspect taking apart the dash will be the end result.
Will update when I gather more info! Thank you again!
Reactions: squeak93
squeak93
2,315
391
164
Joplin, Missouri
Mar 24, 2026
  • Mar 24, 2026
Keep us updated - I usually pay attention to thread starters name but didn't catch that both were your threads. Good luck on both.
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
D
Paint and Body Passenger side leak on carpet
  • dqureshi06
  • May 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 16, 2025
limp
R
Passenger side leak issues and cowl questions
  • Red2valve
  • Jun 16, 2020
2K
1996 - 2004 SN95 Mustang -General/Talk- Jun 28, 2020
7991LXnSHO
M
2006 Major Leak, can't figure it out
  • mpalomba3
  • Feb 4, 2019
2005 - 2014 S-197 Mustang -General/Talk- Feb 6, 2019
racerraj
R
C
Water Leak...passenger Footwell
  • coastiefe
  • Dec 13, 2016
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech Dec 28, 2016
coastiefe
C
