Ok so a couple days ago i parked in the parking lot at college, and by the time i had grabbed my books and got out of the car then walked around the front of it, a lot of coolant had already poured out, i'm talking a puddle about the width of the engine and it was enough to start running down the pavement very quickly. I looked under the car to see something crazy. It looked like someone had turned a bottle of water upside down in my engine bay. So, its really hard to see the bottom of the pump from the top (duh) and if i get underneath to try to check it out i'll catch hot coolant in the eye, so.... All that i can gather is that it SEEMS to be comming from that drilled hole (like the one that's on the top also, where steam comes out if your car overheats if i remember) on the bottom of the pump. It doesn't look like its leaking from the back like a bad gasket. So is my pump probably just shot on the inside or something? I felt around the bottom of it after it dried and i didn't feel a crack, just that premade hole. Any ideas are appreciated.
-E
-E
), and also my 3-ton 4 month old floor jack, used for like 4 occasions, stopped working. When i try to jack my car up, it barely moves up then dies back down. It wont even jack up a person without dying back down some each pump. Any idea whats up with that? Anyways maybe i can fix it or borrow a jack from someone to get this stuff done. I really liked that jack too, cost like 70bucks
. It has fluid too....ugh.
