Water pump bolts
  • Thread starter Thread starter Slowstang96
  • Start date Start date Oct 1, 2008
Slowstang96
92
Tampa
Oct 1, 2008
  • Oct 1, 2008
Do any of them actually thread into the timing cover? I broke 2 of them off, both by the drivers side water passage. Pulling on the TC, the bottom bolt moves as if it either is loose enough or it's stuck in the cover. The other doesn't look like its budging at all.
In other words, if I pry the cover off, are there internal threads on the TC that I'm going to ruin?
I'm off to buy an EZ out kit, but I don't know if that will do much good - its soaked in PB Blaster, I tried to torch it, I cut a slot in the bolt and tried to use a screwdriver - not budging!
Slowstang96
92
Tampa
Oct 1, 2008
  • Oct 1, 2008
ez out not doing anything. any ideas?
P
phutch11
328
Oct 1, 2008
  • Oct 1, 2008
4 WP bolts go to the block and don't thread to the timing cover - these are the two on each side around the water passageways. The rest do thread to the timing cover.
If you have any bolt you can see - grab w/ vise grips and twist. If not, remove all the remaining bolts and take off the WP and timing cover - this can be done with the broken bolts in place as they only thread to the block and are now essentially studs.
Those bolts typiacally rust inside the WP and timing cover bolt holes and sometimes the rust can make them stick to the WP or cover - but they are not threaded to either, only the block.
When reassembling make sure to use plenty of Rtv around the gaskets to keep it from happening again.
Good luck.
Posted via Mobile Device
Beasty306GT
671
Oxford,Mass
Oct 1, 2008
  • Oct 1, 2008
u gotta drill them out...and retap
Slowstang96
92
Tampa
Oct 1, 2008
  • Oct 1, 2008
Yeah, I was able to pry it out enough to see that both bolts are still in the block. I was able to drill one out (breaking the cover in the process.....) the other is still stuck. I'll have to get my long pry bar to get it out and get another timing cover. Anyone have one for sale?
Was hoping to have it running again today, oh well.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Oct 1, 2008
  • Oct 1, 2008
If there is enough of the bolt sticking out you can weld a nut to it and then you should be able to get them out.
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
D
Engine Reusing water pump bolts?
  • dqureshi06
  • Oct 12, 2024
Fox 5.0 Mustang Tech Oct 22, 2024
nickyb
D
Engine Water pump back plate bolts touching timing cover?
  • dqureshi06
  • Oct 27, 2024
Fox 5.0 Mustang Tech Oct 29, 2024
limp
