  • 1994 - 1995 Specific Tech
Water pump, bottom bolt..
  • Thread starter Thread starter bonestock94
  • Start date Start date May 1, 2008
bonestock94
61
NY
May 1, 2008
  • May 1, 2008
This was so much easier on my 92. Ok so I've gotten every other freaking bolt off the water pump except the one closest to the balancer. I figured maybe removing the crank pulley would make it accessible but its almost as if the balancer is touching the bottom of the w/p.
Does anyone have a solution or ideas as to taking of that bolt before I go rent that horrible balancer tool and enter that mess?
FlyBy763
439
Palm Bay, FL
May 1, 2008
  • May 1, 2008
never had a problem with it...just take off the water pump pulley...
my balancer was rubbing on the bottom of it when it went bad, the new one is below it.
bonestock94
61
NY
May 1, 2008
  • May 1, 2008
This one is a pretty new oem replacement from ford racing, like 10k on it. The w/p and crank pulleys are off, thats not the problem. It just that the rubber from the balancer is almost touching the bolt to the point that I'm nowhere near fitting a thin wall socket in there.
FlyBy763
439
Palm Bay, FL
May 2, 2008
  • May 2, 2008
Sounds like youre going to have to pull the balancer off then. Not the factory balancer I assume?
D
Danman765432
471
Nutley, NJ
May 3, 2008
  • May 3, 2008
if the rubber in the balancer is coming out then you need to also change your balancer since its on its way out
bonestock94
61
NY
May 3, 2008
  • May 3, 2008
The rubbers not coming out, its brand new about 10,000 miles on it. It seems like the diameter is slightly bigger than the factory one even though its an oem spec ford racing one. Oh well, got the balancer remover tool so I'll see how that goes tommorow.
D
Danman765432
471
Nutley, NJ
May 3, 2008
  • May 3, 2008
if you have a manual trans you should have no problem with the balancer tool. If you have an auto, I used a big wrench that rests on the water pump to pull the balancer of with the puller.
bonestock94
61
NY
May 5, 2008
  • May 5, 2008
Its a former auto car so I'll use your idea with the wrench and see how it goes. Hopefully its not too stuck. Thanks for the advice
bonestock94
61
NY
May 6, 2008
  • May 6, 2008
Finished everything yesterday, wasn't too bad at all. The balancer came right out just using the tool. Honestly the biggest pita was getting the old gasket off the timing cover
E
Fox Water Pump and Timing Cover on 95?
  • eglick125
  • Apr 1, 2024
1994 - 1995 Specific Tech Apr 30, 2024
85GTStangGuy
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
V belt crank and water pump pulley diameters
  • impropernick
  • Oct 10, 2021
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 10, 2021
impropernick
Engine Coolant leak after replacing water pump
  • 91GTstroked
  • Sep 9, 2021
4K
Fox 5.0 Mustang Tech Oct 28, 2021
91GTstroked
For Sale 97 Cobra with built 99 cobra drivetrain
  • AvalancheSVT
  • May 14, 2022
3K
SN95 Mustangs For Sale (1994-04) May 22, 2022
AvalancheSVT
