Engine Coolant leak after replacing water pump
OldManRiver
197
111
53
48
Central Wisconsin
The hex head bolts that are used to secure the backing plate to the pump have low profile heads,stock height hex head bolts will not let the pump seat properly.This is why I mentioned the height of the heads on the socket head cap screws,the heads would end up being too tall unless button heads were used.
I believe it was FlowKooler that for a time supplied regular hex heads with their pumps and had a lot of pissed off customers with leaky pumps after install.
  • Sponsors(?)
Redfire Fox
57
26
39
45
I kept getting a leak between the backing plate and pump every time I changed the pump due to the backing plate bolts not giving me enough seal pressure. What I did was use two washers for those bolts to give me greater seal pressure because it gave the bolt heads more contact. I just had to make sure the washers weren't hitting the timing cover mating surface. Worked every time.
Reactions: 1 users
chrlsful
109
15
28
Lawrence Swamp, S.Amherst, MA
C if U can ck for flat ona "known flat plane". Too much crank dwn pressure scares me w/a crack. Gasket/snot/glue on pump & block side (I like that red stuff that 'never solidifies/hardens') ...hand tight all round then to 30 lb tq or less...done
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,075
5,140
203
44
Do not torque the water pump bolts to 30lbs. That's twice factory torque. Dealer spec is 15lbs. or about half a ugga dugga.
  • Useful
Reactions: 1 user
