Water Pump Help
sweetlu60
Although I am new to posting on this forum, I have been lurking for a while as a guest. I did a search for my problem, but really did not find what I was looking for.
I have a 1994 Bondurant GT. I need to replace the water pump. When I took it off, it appears that it is a clutchless fan, as it was threaded directly onto the shaft of the water pump. I went to my local parts department, but we could not find it, even though we found several that were identical. Right now I cannot go to an electric fan, so I need to go back to the same type of water pump as is on the car. The pump is the same size, but the flange on the pump shaft is a little larger and the shaft is large, with threading.
Any help would be appreciated.
Sweetlu
