Water Pump Ideas
  • Thread starter Thread starter DocG
  • Start date Start date Jun 18, 2010
DocG
5th graders > me. They're not bant
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Jun 18, 2010
  • Jun 18, 2010
Hey all. I am currently running a Mishimoto alum radiator and dual fan setup. My car has always had problems with running hot. The t-stat and temp sensors are fine. Its been burped and burped again and again. It will heat up to about 190 pretty quick, and just kinda jump around between 190 and 225 while cruising locally or on the highway and this is within 15 mins. Doesn't seem to matter either way. I put it in 5th gear on highway and it will slowly start to creep back down oddly enough.
A little while back my water pump took a dump so I replaced it, with a stock one. I'm starting to wonder if it originally had a high flow or something on it since it seems to run hotter now, even with the alum rad and elec fans.
The only other option I have is to switch back to a stock size water pump pulley instead of the modded one.
Any suggestions on a good high flow water pump for around 200 bucks or less?
I have been looking at Jegs and the Edelbrock Victor series ones, but am unclear if those really flow any better than stock.
Anyone use these?
Any other suggestions?
Thanks!!
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jun 18, 2010
  • Jun 18, 2010
what fan are you running? My stock replacement water pump works great. Car would get a little warm with the clutch fan but with taurus fans and an adjustable controller i have no problems
2000xp8
SN Certified Technician
Aug 8, 2003
8,058
1,643
194
NJ
Jun 18, 2010
  • Jun 18, 2010
The stock ford racing water pump is capable of cooling almost any setup you can throw at it.
If it's installed properly with no leaks, i doubt it's your problem.
Have you pressure tested the system?
stykthyn
5,232
2,652
223
gainesville
Jun 18, 2010
  • Jun 18, 2010
are you sure you have the right pump? If its turning in the wrong direction its not going to cool your engine.
DocG
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Jun 18, 2010
  • Jun 18, 2010
The fans are Mishimoto as well. Bought the kit they sell on Jegs.
Yeah, the system has been pressure tested and tested with the dye stuff. No signs of any problems.
Its quite possible its the wrong direction pump....just took what the parts guy gave me at the store for a stocker.
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Jun 18, 2010
  • Jun 18, 2010
id make sure you dont have the wrong pump then, i dont trust my parts counter guys to do anything other than swipe my card for me. My car stays very cool with the stock pump and an electric fan. You shouldnt need anything crazy too keep cool. Cincy isnt that hot
btw, i was in the area last night at a car club meet. Theres some pretty wild stuff in the cincy area
BYRDPE
1,556
Memphis,Tn.
Jun 18, 2010
  • Jun 18, 2010
remove the under drive h20 pulley and reinstall the stocker or a cobra h20 pulley.
DocG
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Jun 18, 2010
  • Jun 18, 2010
Yeah! There is a Quaker Steak and Lube in Milford OH that gets hundreds of cars every friday night. Always something to do with cars around here!
That was my next option, but since I like wasting money I went ahead and ordered the Edelbrock Victor pump. If that doesn't help, pulley is next. After that, there is no logical reason for it to run hot anymore.
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
  • brandyn200
  • Jun 20, 2026
AeroCoupe
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
