water pump , new engine old style car
guesscrazy
10
Whar waterpump will work with 88 roller block in an 68?The 88 pump is standard rotation but inlet is wrong direction for a 68.I would like to use the serpintine belt system off the 88 but old style pumps are shorter depth.Any ideas how to make this work?
For a serpentine setup you'll need a reverse rotation water pump. If thats a stock 88 water pump it should be reverse. I dont think that they make a reverse rotation pump with the inlet on the side you need. I went through this with my 69 and 351 setup. I just went with the stock water pump to keep the v-belt. I think you will need to buy a different radiator (1970 and up) to match the water pump if you want the serpentine belt. If you change the radiator it would be a cross flow which cools better too. I'm not sure what is shorter in depth in the pumps, I dont remember that being an issue. Sounds like you could get a different pulley to fix that.
