Does the 92 2.3 N/A use the same water pump as the 5.0?? someone told me it does but i doubting that is true.
also how hard is it to change the water pump? is the only thing that needs to come off the pulley??
The water pump is pretty easy to change just drain the coolant and unbolt it. Its been so long since I looked under my 93' that I can't remember how the belts are on it lol I think you just remove tention on the alternator side and slip that belt off. Then remove the radiator hose once the coolant is drained.
