WB reading richer then normal
Thanks yeah cause from the datalog everything else seems normal my Pw and dutycycle at idle is inline with my normal readings just the wideband seems off I’ll re-cal it tmmrw when it’s not raining here and report back
So I had a really hard time re-calibrating the sensor it kept reading error E2 and I checked the resistance of the pins 3-4 on the sensor it read right around 3.5 and the heater circuit had voltage. I finally got it to calibrate but it still seems a bit off on readings from what it use to be. Next step is to order a brand new sensor to see if that fixes it.
