WC t-5 question
JAA55
correct me if i'm wrong but i'm under the understanding that the only manual transmission thunderbirds were turbo coupes, and if it were a turbo coupe transmission is it the same as the WC T-5 found in SVOs? What would you have to do to make the Turbo Coupe transmission fit to a 5.0?
thanks!
depends which year model your talking about pre 87 i believe had a three speed tranny i dont know if these will bolt up but there not the same as the t-5. 87-88 Thunderbird 5-speed transmission is a t-5 tranny that will be a direct fit replacement in a fox body so i hear...and the 89-95 had a M5R2 Mazda tranny...you need to run the tranny numbers located on the tranny to see what you have?
2.3 turbo t5s will fit into a v8 bellhousing. the only thing extra you need is a special pilot bearing. the 4cyl trans has a smaller diameter input shaft, and is rated for less power. considering a 5.0 will blow up a t5 anyway that was made for a v8, and i wouldnt do it
87-88 TC's did come with a WC t-5.
They are more similare to 87-93 4-banger t-5's than they are to SVO t-5.s I beleive the gear ratios are that of the 4-cyl Mustang. I beleive they have a 6 tooth speedo drive gear since they came factory with 3.73's
Rated at 240 ft-lbs
