weak brakes
  • Thread starter Thread starter gnixl
  • Start date Start date Jul 4, 2004
G
gnixl
120
  • Jul 4, 2004
I'm running out of Ideas. 91 vert just doesn't stop well. You can stand on the brakes until the pedal or seatback nearly snaps and it won't even lock up a tire. The old pads and shoes looked OK (barely), now I've replaced:
> New rear drums / shoes / hardware (no leaks from read cyls).
> Front rotors / pads (calipers not leaking, but ????)
The master cyl holds pressure (doesn't sink the pedal), and you can feel the booster work when you start the car, and it hold vacuum after engine shut off. I even screwed the pushrod out another half-turn, no help.
The brake hoses are old, but no cracks.
Any thoughts on what to throw on next?
TIA....
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jul 4, 2004
  • Jul 4, 2004
Fox brakes arn't that great, but they are not THAT bad either. You should have pin pointed the problem first before throwing parts at it. It could be anything and everything who knows. Brake fluid gets contanimated because it is hydroscopic which means it absorbs water, right out of the air. That's why it gets black when it is clear new. Especailly with old lines and seals, air can get in there. The smallest amound of air will cause the brakes to not grab at all.
Firs of all check that the caliper slide pins are moving freely. Then check that the rear drums are properly adjusted. Suck the fluid out of the master cylinder as much as you can and add new fluid, then leaving the cap off open all the bleeders and let it flush out until there is all new clear brake fluid comming out. One more thing, are the rotors and or drums glazed?
G
gnixl
120
  • Jul 4, 2004
Thanks for the suggestions.
I hadn't thought of the brake fluid, wouldn't air in the line make the pedal feel spongy? The pedal feels firm..it just doesn't seem to do much! As near as I can tell, the shoes are out to the drum and the adjuster works freely.
The caliper slide pins don't look really good, but I'm not sure if they're the problem. Any suggestions to troubleshoot slide-pin bind in the driveway with the wheel off? Should I replace the entire caliper?
No glazing, thats why I replaced drums and rotors, I forgot to mention I pulled the new rotors off and had them turned in the hopes it might help to have a more 'aggresive surface'..it didn't.
Matt90GT
3,055
Oregon
Jul 4, 2004
  • Jul 4, 2004
You just figured this out? WOW!
Does your car hold on a hill with the E brake? If not, you need to manually adjust up the rear shoes.
Really the next step is to start measuring. You need to measure the amount of vacuum at the booster check valve and after it. Measure the fluid pressure at each wheel on the car. You may want to stop by like a Midas or something to give you a free safety inspection if you cannot diagnose the issue yourself.
Brakes Front brakes sticking - 1988 5.0
  • 302Blue
  • Oct 18, 2024
Fox 5.0 Mustang Tech Oct 19, 2024
ustacould
D
Resolved 1985 GT brake pedal problems
  • DienstXIV
  • Jun 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2025
DienstXIV
D
1970 brake issue. Bad booster or?
  • All Stock93
  • May 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2025
All Stock93
R
Brake Master Cylinder replacement steps for 2016 S550?
  • Reybeast
  • Dec 16, 2024
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Dec 21, 2024
89ripper
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
