I am guessing a weak starter motor at cold engine is probably a connection problem? Because when the car is warmed up and hot the starter sounds normal, but when it is cold it turns slowly and eventually fires up.
Probably thermal expansion on the loose interface that makes a better connection at warmer temps?
I did a search and found a lot of stuff about weak starters at warm conditions, but nothing about cold conditions.
Anyone had an expierences like this? I will be checking the connections soon...
About 100k on the engine, any idea on how long a starter lasts? I would imagine is it still good for another 50 to 100k....
