  • SN95 4.6L Mustang Tech
Weird blinker question
  • Thread starter Thread starter 95 GT
  • Start date Start date Oct 27, 2005
9
95 GT
32
  • Oct 27, 2005
About a month ago my blinkers started acting funny. They would work, but sometimes they would be at double speed. Now the left blinker is like that 100% of the time, but the right blinker is almost always normal. Anybody else seen this behavior or know what might be wrong??? Any advice will be greatly appreciated. Thanks!!!
ProCharger GT
153
Cleveland
Oct 27, 2005
  • Oct 27, 2005
Fuse?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Oct 27, 2005
  • Oct 27, 2005
One of your bulbs on your left side is burned out.
Put the blinker on and walk around the car and have a look
tomustang
Psychotic Member
3,434
McLean Hospital
Oct 27, 2005
  • Oct 27, 2005
you ran out of blinker fluid, have it flushed and refill it
strokedandblown
Banned
May 3, 2005
555
USA
Oct 27, 2005
  • Oct 27, 2005
seen it 100 times, look right under your fan , while running and you'll be able to top it off, you might have to feel around alittle to find it
tomustang
Psychotic Member
3,434
McLean Hospital
Oct 27, 2005
  • Oct 27, 2005
seriously it's a common problem, the connects inside the blinker assembly are having bad contacts, last time i looked turn signal piece was only 24.95 from Ford, cheap replacement parts to solve the problem.
9
95 GT
32
  • Oct 27, 2005
You mean in the steering column? At the base of the turn signal shaft?
hehehe I said "base of the shaft!!!"
9
95 GT
32
  • Oct 27, 2005
ProCharger GT said:
Fuse?
Dude...I really hope your kidding!!!
G
glitch1985
22
Northern VA
Oct 28, 2005
  • Oct 28, 2005
From personal experience it sounds like there is too much blinker fluid because it's going at different rates. Just my opinion though
bham_gt
94
Birmingham, AL
Oct 28, 2005
#10
  • Oct 28, 2005
  • #10
x2.
stangGT97
1,299
Boston area, MA
Oct 28, 2005
#11
  • Oct 28, 2005
  • #11
i had the same problem, replace the blinker switch in the steering column.
tomustang
Psychotic Member
3,434
McLean Hospital
Oct 28, 2005
#12
  • Oct 28, 2005
  • #12
stangGT97 said:
i had the same problem, refill the blinker fluid in the steering column.
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
K
Electrical Weird horn - headlight issue
  • Kuwait-Foxbody
  • May 27, 2024
Fox 5.0 Mustang Tech May 28, 2024
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
