  • SN95 4.6L Mustang Tech
Weird Braking Problem
  • Thread starter Thread starter MaplesGT
  • Start date Start date Nov 16, 2006
MaplesGT
Rio Rancho, NM
Nov 16, 2006
  • Nov 16, 2006
I Have A 99GT.... I Just Noticed Today Leaving Work I Got To A Stop Light (Going Straight) And The Car Was Braking Perfectly. Until I Started Braking Into A Corner, Then A Nasty Grinding Sensation In The Pedal Kicked It Really Hard. Does Anyone Know What May Be The Problem??? :SNSign:
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 16, 2006
  • Nov 16, 2006
Bad ABS sensor, ABS module, or ABS ring. It is def a problem with the ABS system.
If it keeps doing it or the ABS light comes on you are going to have to fix it.
MaplesGT
Rio Rancho, NM
Nov 16, 2006
  • Nov 16, 2006
How Much Would It Cost To Get Fixed???
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 16, 2006
  • Nov 16, 2006
Depends on what is causing it... Have you done any work near the ABS sensors or rings such as installed new studs or brake work? Do you have different size tires on the front vs the back?
Is the ABS light on?
Was it raining? It could have just been a random glitch?
When the ABS system thinks a wheel is spinning at a different rate than the others, the system gets activated.
merc123
420
North GA
Nov 16, 2006
  • Nov 16, 2006
If ABS light is on get it checked out. Also, check your brake fluid level.
Also, check your rotors for grinding. Maybe the pad is worn?
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
D
Resolved 1985 GT brake pedal problems
  • DienstXIV
  • Jun 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2025
DienstXIV
D
1970 brake issue. Bad booster or?
  • All Stock93
  • May 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2025
All Stock93
Brake issue after changing pads and rotors
  • squirrel0420
  • Jul 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jul 18, 2025
nickyb
