I have a 90 notch 2.3 auto and sometimes I hear a weird clicking noise coming from the dash. It sounds like a relay, but it's more like a telegraph than a buzzing noise. It seems to do this more when the rad fan and/or ac comp are on, and also when the car is cold. Also, if I am driving when the noise occurs, the engine will have a very slight miss. I can't really notice this unless I floor it. This is puzzling because I put my hand under the dash while I heard the noise, and I could feel the cooling fan module making the noise. But why does this cause the engine to misfire?
Let me tell you more about what I have on my car. I have an Accel 300+ ignition box with coil. When I took off the stock fan I had an 'Advance Auto' fan hooked into the stock fan wires. I don't know, it may have been too much for the module. After that, I got a Volvo fan run from the battery through a 30 amp relay, with the cooling fan module running the coil of the relay only. That worked ok until the relay burned out. I had to special order a 70 amp relay and terminals to go on it. Everything is fine now, except for the occasional bout of telegraphy. So why does this affect my engine?
I'm going to try replacing this and see what happens. A $1.29 capacitor is a lot cheaper than the ~$100 module. And the new cap is rated at 35V, not 16V, so a spike is less likely to take it out this time. I think that's what happened, anyway.
