Weird Clunk
k12
130
Hey all,
My 90 gt w/185k 5 speed makes a wierd clunk when I pull away from a stop. It does it eaier if I am turning when pulling away. Its coming from the front. Any ideas?
Thanks,
Kieran
Time to start checking all of the small things:
bad strut
bad ball joint
bad tie rod
bad bushing
loose wheel
bent driveshaft
unbalanced driveshaft
torn torque box
bad shock
These are just a few things that come to mind. It could also be something as simple as the brake caliper hitting the slide pin?
you know what...I have the same thing, but only when I back up.
It's DEFINITELY comming from the suspension in the front right side, but I haven't been able to pinpoint it. I had the ball-joints & tie rods checked at the chasis shop when my car was there and they said they were fine...I guess they could have gone bad after I had it there? :shrug:
Thanks for the ideas guys. I will crawl uder there tonight and have a go at it. What's the best way to check ball joints. I remember something about only being able to check them with the vehicle on the ground and using a big pry bar?
