  • 1994 - 1995 Specific Tech
Weird Cooling Issue
  • Thread starter Thread starter 95strokerPSU
  • Start date Start date Mar 12, 2007
95strokerPSU
986
Sacramento from Philly
Mar 12, 2007
  • Mar 12, 2007
Cars runs extremely well except for this one small thing. Whenever I start from a cold start, in about five minutes the stock temp gauges shoots up to L and the high speed fan comes on while the Autometer gauge sits at around 100. Then the Autometer gauge shoots up to about 225 for second or two and then both gauges start to come down together and stay at normal temp. Any ideas?
T
tjh566
608
Northern Va
Mar 12, 2007
  • Mar 12, 2007
how is the autometer guage connected, does it have its own seperate sending unit?
95strokerPSU
986
Mar 12, 2007
  • Mar 12, 2007
Yes and it is on the radiator side of the thermostat.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Mar 12, 2007
  • Mar 12, 2007
i would say either air in the line or a bad t-stat
take the t-stat out and put it in some water in a pot on the oven. stick a thermometer in there and see what temp its opening up
HISSIN50
34
129
Mar 13, 2007
  • Mar 13, 2007
Electric or mechanical AM gauge?
I'd also want to see if air is bleeding into the system as the coolant contracts. It really is kind of a strange symptom to have happen every time, and have a gauge on each side of the t-stat do it. Interesting.
As an aside, next time you have stuff torn apart, you might want to switch the gauge senders around (if your t-stat sticks, your AM gauge is going to be slow to let you know about it).
Good luck bud.
95strokerPSU
986
Mar 13, 2007
  • Mar 13, 2007
I was thinking either air or bad t stat too. In the past, any air has worked it's way out of the system after the first drive and on Sunday I drove it for almost three hours straight. I'm leaning towards t stat.
R
R100RT
362
Sonora, CA
Mar 14, 2007
  • Mar 14, 2007
Your AM gauge is downstream of the T-stat. The factory gauge is upstream. On the T-stat opens, the AM gauge sees the same temp as the factory gauge.
Eric
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
G
2016 GT, Cold Air/Tune Trouble (overheating) . Advice/Help Please!
  • GLStang
  • Sep 6, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 6, 2025
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
