Weird Noise coming from engine bay
94stangfan
290
Indianapolis, IN
All,
I have a noise that sounds like it may be a mis-fire or something banging in the engine bay area. The problem is that I cannot make it happen when the car is in park. I can hit the throttle and it revs and sounds fine.
If I am moving and put it under a slight load (around 1500-1800 RPM) I can hear it. It seams to go away any higher than that.
I tried brake torquing to see if I can get it to happen, and that only results in tires spinning with no noise.
Any suggestions to find out where this is coming from and identify how to fix it?
I did have a problem where I didn't tighten my distributor enough and it adjusted itself out of time, but I had this fixed prior to hearing this noise. I have the timing set at 13.
I haven't rechecked the timing since I heard the noise, but will do that later.
This is my 95 GT with an Explorer engine (just finished the swap a while back).
Thanks,
Keith
  • Sponsors(?)
ninetyfourcobra
9
Helmand Province, Afghanistan
I had a similar problem which turned out to be a cracked spark plug. If it is an ignition problem though I think it would be more noticible at high rpm's. Either way before you start investigating the timing I would start by trouble shooting all of your plugs and wires, coil, etc.
94stangfan
290
Indianapolis, IN
Interesting thought. I will look into that. I went thru and all the plug wires seem to be on correctly. I haven't tried taking off the wires and putting them back on. The cracked plug is definitely something I should look into. Although all the plugs were new when I put the engine in, there is always that possibility.
64post
45
Sonoma Calif.
You could get someone to torque it slightly without moving the car in a darkened area so that you can see the spark jump or spray some water (with salt added) from a pump/mist bottle around the plug wire connections, this makes for a good ground for stray electricity, then you'll know what kind of condition the tune up parts are in, be careful not to run your car into a wall or worse.
Thread starter Similar threads Forum Replies Date
S Weird noise coming from under the middle of car? 01 Mustang GT 1996 - 2004 SN95 Mustang -General/Talk- 2
Z Weird Noise Coming From Gauges Fox 5.0 Mustang Tech 3
Rasikajay Weird clicking noise coming from dash SN95 4.6L Mustang Tech 9
04YELLOWGT Blower Guys Come In (Weird Noise) SN95 4.6L Mustang Tech 2
C Weird noise coming from under the hood Fox 5.0 Mustang Tech 5
brandonh06 Weird Metal To Metal Noise Coming From The Engine? Fox 5.0 Mustang Tech 2
S Weird clicking noise coming from dash 2.3L (N/A & Turbo) Tech 11
M Weird Noise Coming from Car 1994 - 1995 Specific Tech 1
V Weird "chirping" noise coming from the rear when driving....? 1996 - 2004 SN95 Mustang -General/Talk- 2
Evenflow Weird noise coming from engine after shutting door? SN95 4.6L Mustang Tech 4
paddyrk Electrical Starter solenoid making weird noise and not starting Fox 5.0 Mustang Tech 3
R Right rear clunk when hitting bumps 2015+ Specific Tech 6
justin82 Fox weird noises? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
S (HelpPlease)Weird slapping noise under valve cover after Cam Install+Rebuild, 2001 SVT Cobra Forged Rebuilt. SN95 4.6L Mustang Tech 9
T 2012 V6- OEM Blower Motor (fan) making weird noise 2005 - 2014 Specific V6 Tech 0
B Mystery Drone SN95 4.6L Mustang Tech 2
8 2004 Mustang Gt Weird Noise Help 1996 - 2004 SN95 Mustang -General/Talk- 1
Chris Lennon Weird Noise While Ing Head Scratcher 1994 - 1995 Specific Tech 5
MustangGT559 Fox Weird Popping Noise When Turning 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
A Engine Car Makes Weird Noise SN95 4.6L Mustang Tech 0
I Drivetrain Weird Transmission/clutch Noise Fox 5.0 Mustang Tech 1
Aspylacide Weird Noise 1996 - 2004 SN95 Mustang -General/Talk- 0
P 2006 Gt Weird Noise 2005 - 2009 Specific Tech 2
91redFox Weird Rear End Noise? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
J 94 Mustang Weird Noise In Rear 1994 - 1995 Specific Tech 4
trinipapy Engine Weird noise when pounding the gas. Fox 5.0 Mustang Tech 8
M 03 Cobra weird noise need help!! SVT Tech Forum 1
rogerz weird noise when i release clutch Fox 5.0 Mustang Tech 10
mob Cranks but no start, weird noise w/ video Fox 5.0 Mustang Tech 44
S Weird noise in exhaust SN95 4.6L Mustang Tech 29
RuBiXQ 2001 Mustang GT Weird Engine Noise SN95 4.6L Mustang Tech 17
jpplaw Weird Engine Noise 2005 - 2009 Specific Tech 2
9 weird noise 1994 - 1995 Specific Tech 5
J Weird noise need some help!! SN95 4.6L Mustang Tech 2
Blackone51 weird beeping noise when start car SN95 4.6L Mustang Tech 6
cammngt weird noise from gauge cluster SN95 4.6L Mustang Tech 2
O Weird Hissing Type Noise SN95 4.6L Mustang Tech 10
00stangv6lr Weird noise SN95 4.6L Mustang Tech 3
M weird ticking noise SN95 4.6L Mustang Tech 3
mustang50v8 clutch making weird noise SN95 4.6L Mustang Tech 1
Spro Got this weird noise 1996 - 2004 SN95 Mustang -General/Talk- 0
N Weird whistling noise Fox 5.0 Mustang Tech 1
K Hearing weird noise from the REAR 2005 - 2014 Specific V6 Tech 1
blackstallion89 Weird Noise Fox 5.0 Mustang Tech 4
W Weird Clicking noise when i turn on a.c. SN95 V6 Mustang Tech 2
K Exhaust is making weird noise and lost some engine power, plz help... Fox 5.0 Mustang Tech 6
R weird noise, stuff leaking onto the exhaust SN95 4.6L Mustang Tech 3
sn-95matt5-0 weird popping noise 1994 - 1995 Specific Tech 22
georgio440 Weird noise under moderate acceleration from a stop 1996 - 2004 SN95 Mustang -General/Talk- 4
georgio440 Weird noise under moderate acceleration from a stop SN95 4.6L Mustang Tech 3
