  • 1994 - 1995 Specific Tech
weird pops... HELP!!!!!!
  • Thread starter Thread starter 95cobra50
  • Start date Start date Apr 25, 2004
9
95cobra50
167
  • Apr 25, 2004
my car runs pretty good upto 4,800rpm then it starts poping like its redlineing. This all started the other day out of no where. I changed my plugs two weeks ago so it couldnt be that and i only run 93 gas in it. Anyone have an idea whats going wrong???
F
FEESER 94 COBRA
142
  • Apr 25, 2004
Check your wires first to make shore there on good. allso if your valve springs are old they could be weak
JJ95GTID
1,141
Phoenix, AZ
Apr 25, 2004
  • Apr 25, 2004
If you are pushing 80K+ milage it may be time to put new IAT and ECT sensors on the stang. I had a rattling noise under load around 4K rpm and now it is gone.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Apr 26, 2004
  • Apr 26, 2004
Do you know what pinging sounds like? If you don't, it will sound like rocks rattling inside a tin can.
Have you don't anything to the car in the past few weeks? Tried running the codes?
Scott
H
HazMat404
1,749
Apr 26, 2004
  • Apr 26, 2004
well there is such a thing as running too high of octane. if your car is mostly stock and ur running 93 then you are probably wasting money, gas and performance. higher octane requires more spark/compression to burn. there is a possibility that 93 is too much especially when you are pumping a ton of it at 5000rpms and its not burning properly. if you arent detonating with any other octane, put in lower and lower octane.
thats kinda a universal stab at it cause so many people run way too high of octane
9
95cobra50
167
  • Apr 26, 2004
well when i got the car it was stock and i ran 93 and now i have long tubes, off road h pipe, in the process of switching from flowmasters to magnaflows, k&n replacement filter. My wires are stock and im going to be replacing them with msd wires and I;m also pushing 76XXX miles atm.
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
