- Feb 3, 2004
- 5
- 0
- 1
When taking the seats out of my wife's '94 Mustang, I found that the seat motors didn't function. That made things very enjoyable, let me tell you.
While it was out, before reassembling the seats, I went through to test and see what was wrong. I tested voltage at the plug coming out of the floor, 12V. I tested voltage going into the motor plug, 12v there too, or -12v, if I tried to go the opposite direction on the switch. All as was expected. Felt the motor while actuating and no sounds, not even a feeling of a kick. Okay, bad motors.
Really? I thought - two at the same time? That seems pretty unlikely. But I ordered a set of replacement motors from Two Guys One Garage, and just finished getting them all installed. Got them wired back in. SAME ISSUE. They don't even try to run - no spinning, and I've got 12v all the way up to the motor with the switch actuated.
I also got a hammer and gave the seat slides a couple of firm smacks while actuating the switch, in case it was stuck and still nothing.
I'm out of ideas, anyone else have a theory?
edit:
I also want to add, I had disconnected the motors originally and ran them without any load on them to see if it was a bad motor or if the seats were jammed, and the motor did not spin while unloaded, so it doesn't seem to be jammed either.
edit:
