Weird problem after changing heater core...
PeteyAce
346
im not leak everything is fine, heats blowing out nice and hot but weird thing is my temp goes up when i have the heat on (wouldnt it cool the car). goes back down and goes back up but never at a constant temp, but this only when i have the heat on.
Did you "burp" the system. That is, get all of the air bubbles out.
With a cool engine, jack the front drivers side of the car up to lift the radiator neck above the rest of the cooling system. Next, remove the radiator cap, turn on the heater, and start the car. It's important to turn the heater on to let all of the coolant circulate, not just what's in the block, etc.
You'll notice air bubbles "burping" out. Let it run like that for 15-20 min or so and get all of the bubbles out. Obviously, do not touch the throttle or you'll shoot coolant all over the place. Put your cap back on, lower the car and take it for a drive. If it's not fixed, come back and try again. If that still doesn't fix it, then you may have other issues.
You don't need to turn on the heat. Coolant circulates through the heater core whether the heat is on or not. Turning on the heat just allows air passing through the heater core to enter the cabin. It has nothing to do with coolant flow.
What you're seeing my very well be air-bubbles in the cooling system showing their presence as the thermostat opens and closes.
Circulating air through the heater core may be changing coolant temp enough to actuate the t-stat.
I'd do what is suggested above and keep burping the system. Come back and hit us up if there's no change after a reasonable amount of time.
