  • 1994 - 1995 Specific Tech
weird problem HELP ME!!
  • Thread starter Thread starter rgs
  • Start date Start date May 15, 2007
rgs
124
Vancouver, Canada
May 15, 2007
  • May 15, 2007
k i swapped out my ebay cold air intake that i had and put back in the stock airbox with a k&n.
while i was at it i cleaned the maf, iac, and tps. i got it all together and now it idles a lot better but when im driving 1st and 2nd gear feel fine, but 3rd and 4th feel sluggish in the lower rpms. almost like it wants to bog down.
this just started after putting back on the stock airbox.
anyone have any ideas??
94superstang
76
  • May 16, 2007
At wot do you have any power lose? When my maf went bad it did something similar but I had a hug loss of power when getting on the gas. As far as normal driving it did the same thing as you describing.
HISSIN50
34
129
May 16, 2007
  • May 16, 2007
Reclean the MAF if your filter was oiled at the time of installation.
I agree that the MAF might be acting up at higher RPM's/speeds/loads.
Good luck.
C
chuck943
262
north carolina
May 16, 2007
  • May 16, 2007
You may also have to do a stradegy reset. PCM uses a baro reading from MAF sensor,it isn't a real baro reading but an infered value but if your baro reading was say 145 because of a dirty MAF then PCM thinks you are below sea level. Usually doing several WOT burst will reset it but sometimes you will see a stubborn one and you have to unhook battery for about 30 min and let it reset that way.
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
J
Reduced power in 1st and 2nd gear
  • jimted79
  • Feb 25, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 25, 2025
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
