Weird Problem
slow5poh
Senior Citizen
Jul 6, 2005
273
Citrus Heights, CA
Ok. here it is. I rented a garage at the apartment i live in. I only have been driving the stang like once a week or less. So, i leave the negative battery cable unhooked as not to drain the battery from sitting there. Never had a problem till today. Good power, i push in the clutch and turn the key, it makes a weird pop noise and the whole car shuts off. But it never even cranked once! It just like zapped off! All battery power gone. They only way i could get power is if i disconnected the battery and hooked it up again. After three times of doing this, it finally started up like normal. WTF?? makes no sense to me at all. :shrug:
May not the be the problem, or you could have already thought of it, but how are the cables? I had to put new cables on mine a couple summers ago cause it didnt ever wanna start consistently. Put new ones on and it cured it, my ground cable was really crappy where it was touching the motor.
A little corrosion may have built up since last time or the cable was not quite as tight since it had been R/R'd one since then, etc etc. Just tighten it up and see how it does.
Also, one of those terminals with the on/off knob (popular in marine applications) might work well - I used one on a car which was seldom driven.
Good luck.
Also from loosening/tightening the cable on the terminal, the terminal itself can become weak and even tear away from the battery. This happened to me after countless times working on my car and the battery was toast.
