weird sound from trans
fast94mustangGT
60
I just got my car back together. changed my oil pan gasket,clutch,TOB,shift fork,TOB retainer,and installed a steeda clutch quadrent kit. now theres a kind of whine coming from i think the transmission, sounds more like a whurrr than a whine. the sound increases with rpms and sometimes stops if i let out of the gas while in gear and it gets down to about 1800rpm's. do i have the steeda kit adjusted wrong or is it something else???
you have the STEEDA ADJUSTABLE CLUTCH CABLE QUADRANT KIT you better check your adjustment if your throw out bearing is making contact with the pressure plate when clutch is disengaged which is what it sounds like its doing you will be replacing that throw out bearing very soon in the future. i would not drive until i ensured this was fixes unless you like pulling trannys....
