Engine Weird Start problem 89 GT
Aoneill5.0
38
EASTERN CANADA
Hey,
Just bought my GT a free days ago
155k
Edelbrock Intake
KN Cold air are the only mods I can tell
Anyway
I’ll get right to it
Shut it off yesterday,
Wouldn’t start but cranked fine.
I learned I had good fuel at the rail and spark was decent
Plugs were dry bigtime..injectors not opening obviously
After many thoughts and wire wiggling
I disconnect the BAT +/-
Let sit 10min.
She fired right up
Ran ok to get me home
Now it will only start after a full disconnect
The IGN Module is my only suspect as it has a small crack on the plug area but I’m not sure if that is in line with telling the injectors to open at startup ceanking
Any advice or similar issues are appreciated
Must be a relay or something associated with the EFI
Thanks Folks!
Reliving my youth,
Love the car!
Aoneill5.0
38
EASTERN CANADA
I actually did that during the initial diagnosis
As I thought I may of flooded ot
That’s the clearing procedure as I recall from school..
Thanks tho for the reply
The fact that I can get it started reliably unhooking the bat tells me something to do with fuel/ecu is being held open/closed with Voltage…
I’m that guy who loves learning from this stuff..
Reactions: 1 user
General karthief
Mod Dude
Aug 25, 2016
24,064
8,899
203
polk county florida
Thanks ti jrichker and others for putting together this, read and follow the instructions.
Aoneill5.0
38
EASTERN CANADA
Well.. car is running,
Removed Battery
Cleaned as many engine grounds as I could find.
Reinstalled battery
Charged it up as it showed 12.45V but was only 20% on charger
Car fired right up and I could not replicated the earlier problem/scenario
We will see I guess.
Still plan on going through wiring with a good clean and replace a few sensors..
Mustang5L5
Put lubricant all over the balls
Mod Dude
Feb 18, 2001
39,736
15,516
224
Massachusetts
I would pull the ECU and inspect the capacitors.
Given that you said it would not start until a full disconnect, i wonder if some/all are bad as caps tend to go through a charge/discharge state depending on power being applied. Could be the reason why it didn't run again until a full disconnect.
  • Agree
Reactions: 1 user
