I did a search in this forum and follwed the instructions. I guess there are a few diffrent ways but I have done this now 4 times and like the following method: Find TDC for #1 on the compression stroke
Loosen poly locks and wait for the lifter to bleed
Tighten poly locks by hand until slight resistant is felt on push rod
Tighten 3/4 turn and lock set screw
Turn crank clockwise 1/4 turn and adjust next valves following the firing order. When done checking one last turn of the crank puts me back at TDC #1 compression stroke. I hope this is right and worked for me 3 diffrent times I adjusted them.
I used the 3/4 turn as specified by Trick Flow. I suppose anywhere between 1/2 and 3/4 is acceptable.
