Weird vibration from 3200 to 3700
  • Thread starter Thread starter 88-378
  • Start date Start date Oct 7, 2011
88-378
14
Alpharetta, GA
Oct 7, 2011
  • Oct 7, 2011
Weird vibration from 3200 to 3700 - bad wires!!!
Like the title says. it is smooth to 3200 and smooth after 3700 Has anyone had a problem similar to this? I can pretty much rule out the drivetrain and suspension.
why would it only do it for 500rpm's?
I think it is a miss..ignition system?
what do you think? I am putting the car up next weekend to check out everything anyway. (my car is basically brand new front to back. it is fresh off a complete resto minus paint) I am almost finished with breaking the clutch in. could it possibly be the clutch not broken in yet?
Mustang5L5
Mod Dude
Feb 18, 2001
43,249
17,934
224
Massachusetts
Oct 8, 2011
  • Oct 8, 2011
I had the same thing happen. Since I did a 5-spd swap at the same time this happened, I assumed it was a balance issue.
Drove for a year living with it. Happened to check codes one day and did a cylinder balance test and discovered cylinder #4 was dead. To make a long story short, the injector was completely dead. I drove around for over a year on 7 cylinders and didn't even realize it.
Admin Dude
Jan 4, 1985
43,062
21,240
234
Box behind Walmart
Oct 8, 2011
  • Oct 8, 2011
Does it vibrate only while under power or does it also do it when coasting?
88-378
14
Alpharetta, GA
Oct 8, 2011
  • Oct 8, 2011
it does it a little while coasting. not as bad as when I am on the gas.
It doesn't shake the car either. so it's not that viloant of a vinration, but is noticeable.
88-378
14
Alpharetta, GA
Oct 8, 2011
  • Oct 8, 2011
I guess I will be testing a few things. I plan on putting new plugs in, so I will see what that tells me.
BlackGT89
774
Huntsville, AL
Oct 8, 2011
  • Oct 8, 2011
If it's related to engine RPM maybe your harmonic balancer is starting to go ?
Mustang5L5
Mod Dude
Feb 18, 2001
43,249
17,934
224
Massachusetts
Oct 8, 2011
  • Oct 8, 2011
Do a cylinder balance test as part of checking the engine running codes. It will tell you if you have a misfire
88-378
14
Alpharetta, GA
Oct 8, 2011
  • Oct 8, 2011
I have a code reader and a book. I also need to get it back down to Atlanta Chassis dyno. I need it checked.
hold up. I think i have a bad wire. So i guess i have been running on 7 cylinders....LOL
88-378
14
Alpharetta, GA
Oct 10, 2011
  • Oct 10, 2011
Well, well, well.
Had a bad wire. Just ordered a new set.
BlackGT89
774
Huntsville, AL
Oct 10, 2011
#10
  • Oct 10, 2011
  • #10
Glad you found it !
88-378
14
Alpharetta, GA
Oct 10, 2011
#11
  • Oct 10, 2011
  • #11
thanks. just hope i didn't damage anything. rings, piston, valves, etc...
A good friend and shop owner was messing with me telling me I need to re-ring that cylinder.... then he started laughing. He said it should be fine...
Mustang5L5
Mod Dude
Feb 18, 2001
43,249
17,934
224
Massachusetts
Oct 11, 2011
#12
  • Oct 11, 2011
  • #12
Glad you found it. You probably weren't 100% dead onthat cylinder, so i wouldn't worry.
When i put a new injector in, felt like i gained 50HP.
88-378
14
Alpharetta, GA
Oct 11, 2011
#13
  • Oct 11, 2011
  • #13
You did! If i take my 405 at the crank, divide it by 8 and you get 50hp! LOL
It was probably my fault when i repaired a wire. Their must have been another small cut in it somewhere. I have a new set of FRPP wires coming. Plus i was getting crazy readings from my ohm meter.
Went to black wires for a more sinister look!
88-378
14
Alpharetta, GA
Oct 12, 2011
#14
  • Oct 12, 2011
  • #14
New wires in. ran codes and a balance test.
All is good.
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
N
Vibration issue
  • Nicolaj
  • Apr 14, 2024
Classic Mustang Specific Tech Nov 8, 2024
AeroCoupe
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
