Weld Draglite/tire Sizes
  • Thread starter Thread starter Bretkissick
  • Start date Start date Oct 14, 2005
Bretkissick
185
Palm Harbor, Fl
Oct 14, 2005
  • Oct 14, 2005
You see all these beautiful Mustangs around with the Draglites. When I finally get mine, What size rims and tires do I want, What size do you guys use? I would love to see some good pictures with Stangs and Draglites. (or a link that might have some good pictures)
I believe the rear wheels will be 15x8 and the fronts will be 15x4 (I like the skinny ones in the front).
Thanks Everyone!
flyinghi3
313
Manorville, LI
Oct 14, 2005
  • Oct 14, 2005
i'm running 15 X 3 1/2 up front and i think there 15X8 out back. check out my link below to see pictures with the welds.
86_stang
37
Annapolis. Maryland
Oct 14, 2005
  • Oct 14, 2005
Do you have power steering still with those skinnys or manual cause i heard if you have power steering that those tires are horrible.
flyinghi3
313
Manorville, LI
Oct 14, 2005
  • Oct 14, 2005
i have power steering, and have no problems at all. i have had them on my car since 97 and to me there is no driving issues at all with the skinnies.
T
tjm73
2,418
Rush, NY
Oct 14, 2005
  • Oct 14, 2005
I used to run 15x4 and 15x8 Draglites on my car before I changed the look with new wheels. I ran 165R15's and 275/50R15 tires. The rear wheels had 5.5" backspace and I ran a 3/16" wheel spacer to solve some minor, occasional off camber rubbing. Were I to do it over I'd run 265/50R15's on the 15x8 wheel in the back and 15x6" wheel with 195/60R15's in the front on a street car.
Reactions: Scrapla347
MrKwik
1,008
Kansas City, Kansas
Oct 14, 2005
  • Oct 14, 2005
I have draglites on 2 of my cars and both are 15x8 with 5.5bs rear and 15x3.5 front. Front tires are 165-R/15 and rears are 255/60x15 on one and 10.5x26" slicks on the other. The slicks should be the same size as a 275/50-15 and I had to do some clearancing on the inner wheelwell near the shock mount. I also dont have quad shocks. I think they would fit if flipped but definately not in their normal direction. The 255's will clear quads fine. And I dont know what power steering has to do with anything. I have run skinnies on PS cars since the 80's. You just can get stupid and go flying around corners with them. The are pretty much meant to go straight.
MustangMulch
303
Santa Clarita, CA
Oct 14, 2005
  • Oct 14, 2005
On my original set of draglites (which lasted 2 days), I ran 15x3.5 skinnies in front, and 15x8's in the rear. Those skinnies are a bad idea for the street. I noticed a huge difference in handling as soon as I got them put on. They didn't feel right for driving on the street, even under normal driving conditions.
Anyway, trying to take a curve at about 60 mph (which I could do easily with fatter wheels up front), i turned the wheel, but my car kept going straight right up a curb, missing a lightpole by about 12 inches, and stopping about 2 feet short of a 10 foot drop into a field (this was in an industrial center). I smashed up my front bumper and taco'd the skinny, and bent the $h|t out of my rear wheel. So my brand new draglites were ruined. I'll never do that again. Point of the story is skinnies are not good for daily driver street cars, even though some people haven't had good luck with them.
Also, with 15x8's in the back with 5.5 backspacing, I had major rubbing problems on the quadshocks and tailpipes with 255/60 tires. I don't think turning the quads would've given me enough clearance not to rub.
These days I run 15x7 draglites all around and it is a much better setup for the street, although I wish I could have 8's in the back to run some 275s.
2002whitegt
179
12
Houston TX
Oct 14, 2005
  • Oct 14, 2005
I run 15x5 in the front with 215/40 and 15x8 in the rear with 275/50
it handles allright.
04sleeper
2,674
14
89
Dallas, TX
Oct 14, 2005
  • Oct 14, 2005
The problem with Weld Draglites is that they only make the 8 inch wide rim in 4.5 inch or 5.5 inch backspacing. Leaving the rim sticking out of the fender or sticking in too far. They did make some for a while that had the right BS but they discontinued them. They were called Draglite XP's.
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
Hit something exiting
  • Creomod
  • Mar 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
General karthief
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Tire size question 1986 gt hatchback
  • B0udreaux
  • Jan 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 17, 2026
B0udreaux
