  • 1994 - 1995 Specific Tech
Weld Pro Star B/S Question
  • Thread starter Thread starter badingle
  • Start date Start date Nov 27, 2004
badingle
127
Portage, Michigan
Nov 27, 2004
  • Nov 27, 2004
Does anyone have the part numbers or b/s n bolt pattern for Pro Stars with stock brakes???
I want to run 15x3.5 and 15.8
Thanks,
Andy
stangbanger94
203
Bergen County, NJ
Nov 27, 2004
  • Nov 27, 2004
get ready to grind your front calipers a little bit for those 15x3.5,s It's the only way they will fit, and you have to run spacers. I had to do it on my 94, but it was well worth it, the car looks sick with the pro-stars
badingle
127
Portage, Michigan
Nov 27, 2004
  • Nov 27, 2004
Thats fine.....i need some b/s specs and spacer sizes
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Nov 27, 2004
  • Nov 27, 2004
I have seen some say that they did not use spacers but not only did they have to remove material from the calipers they also had to remove the bar from the calipers to make it happen
Later
Grady
Stangfreak95
add a 4
3,571
In your sister. If none, your mom
Nov 28, 2004
  • Nov 28, 2004
I suggest you get the 15x4 instead of the 15x3.5 if you're gonna use it as a daily driver. For 1/2 inch of more "security", you'll have like 1/4 of a pound heavier than the 15x3.5. If it's only for track, take the 15 x 3.5
My 15x4 weight 10pds each and my 15x8 that I used to have weight 15pds each. My 15x10 weight 18pds.
Anyway here's the part numbers that you want:
15 x 3.5 = WLD-96-54200 (1.75in backspace)
15 x 8 = WLD-96-58210 (5.5in backspace)
If you do decide to get the 15x4 = WLD-96-54202 (2.25in backspace)
Here's a link to HOW TO FIT A WELD WHEEL ON A SN95
badingle
127
Portage, Michigan
Nov 28, 2004
  • Nov 28, 2004
Thanks man! Exactly what I was looking for
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
