weld prostar 3.5 skinny question
jwalker
405
millersville,pa
when you say to completely remove the cross bar. Do you mean this?
How far up do I remove it?
Then I will also need to grind the caliper down some as well?
Obviously I am putting 3.5 X 15 prostars on the front.
Thanks
yea ive done this on my 01 GT and 94GT with the stock brakes, and yes you must grind the caliper bar, but not all of it.
I had to grind more off the ends/edges, rather then the middle of the bar. I took about 1/4" off, or so.. not very much at all.. I wouldnt remove the bar all together, no need for that.
Just grind about 1/4" and see if that works, spray paint the caliber bar then throw the wheel on, tighten it down with 2 lugs, then spin the wheel, if it rubs it'l rub the paint off on that spot.then youve found the area that needs metal removed from.
my problem was the middle of the bar... thats had to be ground down mroe and beveled the bottom edge and a nice angle. then you can leavve alot of the bar.
I had to do this with a dremel which SUCKED
and you need a 7/16th spacer
