WELD WHEELS???? "REAR'S"
Muirracing
23
Louisville Ky
Has any one put 15x9 with 5 and half backspacing WELD wheels on the rear of a FOX chassis?
I have a set of 265x50x15 Tires.. was wondering if the 9 inch whide Rims
will fit????
PLEASE ANY ONE>>>>> and pictures would be awsome, and great help ......
Not the 15x9's.........but they are 15x8 with 5.5" back spacing and 265/50/15's. I had a rubbing problem on the quads and tailpipes. Had to remove the quads - flipping them did no good - and tweak the pipes a little, but they fit good now.
They will fit just like the more common 15x8 (with 5.5" BS) except be an inch wider on the outside. This will put the tire right inline with the fenderip, so you will probably want to roll that al ittle if it looks close. I considered them, but found a great deal on a set of 15x10's with 6.5" BS -- which sits at the same spot on the outside, just an inch further inside.
OK... thanks for your help... I GUESS next thing I'm wondering is ????
For the ones that have put the 15x8 on there car does it look as if
I would have enough room for the 15x9 >>>???????
I still want to use the 265x50x15...... THat I have,.....
THANKS<<< AGAIN
You should have no problems. I currently run the 8" draglite w/5.5 BS with a 275/50/15 BFG Radial T/A with saleen lowering springs and they fit nice. (had to pull the quads) The 15X9 weld will fit. Friend of mine is runnin the 9" weld with a 295 tire. If clearance is an issue just pull the quads.
Muirracing said:
THATS what I was wanting too hear..... Someone that has the wheel or
that is using a WELD 15x8
WOW>>>>> 295's...... are those with Tailpipes on too?
KWEL>>> thanks again...
Say wha???
I told you they would fit...I've run 15x8's and 15x10's..with a couple different backspacings and multiple tire sizes. :shrug:
I KNOW YOU DID !!!!
I know you told me and I appreciate it too...
I just wanted more input as well... you know others that have done it
I feel good now about my purchasing the wheels...
I'm going to place the order Today...Thanks,, ALL>..
I think I'm going with the 15x9's with 5 & half backspacing.... I have the 265 to put on them .,,. I cant wait to see what it looks like..
Here's some pictures (we'll see if I can attach them!) -- these were when I was trying them on [checking for rubbing/potential interference points] -- all stock suspension/rear at the time, except for the quad shocks which will absolutely not fit with more than 5.5" BS.
EDIT: Just for clarification - these are 15x10 with 6.5" BS.
