  • 1994 - 1995 Specific Tech
well...changing head setup
  • Thread starter Thread starter 96darkhorse
  • Start date Start date Sep 29, 2004
9
96darkhorse
693
wilmington, california
Sep 29, 2004
  • Sep 29, 2004
well..i was coming close to installin my gt40p/edel perf/comp xe274hr setup..but i decided to ditch the irons and go aluminum!!! what heads do you recommend with intake and cam? the cam has a .555/.565 lift and is good from 2200-6200 rpm.....what numbers would i be putting down....i guess i would rather do it right the first time and go aluminum..thanks
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Sep 29, 2004
  • Sep 29, 2004
AFR 165's, TFS twisted wedge, or the Edelbrocks will give you some GREAT power. I dont know much about how that cam will work but im sure it will do fine.
Hopefully others will chime in....
9
96darkhorse
693
Sep 29, 2004
  • Sep 29, 2004
ttt
GTJake
3,049
Ann Arbor, MI
Sep 29, 2004
  • Sep 29, 2004
I believe darkpony on corral made something like 31xhp/31xtq with that cam and some AFR 165s.
Jake
GTJake
3,049
Ann Arbor, MI
Sep 29, 2004
  • Sep 29, 2004
Found it...
302, AFR 165's, comp cam, TFS Track Heat, BBK LT's, Dr. Gas 3'' X, Mac Flowpath Catback.4.30's
320RWHP 316RWTQ
Grn92LX
Fidanza Man!
6,819
64
129
New York
Sep 29, 2004
  • Sep 29, 2004
Jake, I dont think he's running the 274 cam though.
He also did 299/325 with P heads, cobra intake and an AFM b25 cam
My advice is TW heads (or track heat heads since you'll NEED the better valve springs) and an RPM intake. You will need a 410 gear and I recommend 1 5/8" longtubes and porting the inlet for a 75mm TB
95snoozer
2,572
RCR
Sep 30, 2004
  • Sep 30, 2004
Jake
his cam is custom and thast on stock computer
95snoozer
2,572
RCR
Sep 30, 2004
  • Sep 30, 2004
oh yeah and get any of those 3 heads
9
96darkhorse
693
Sep 30, 2004
  • Sep 30, 2004
im gonna run the performer intake....i dont wanna change the intake/cam setup i have..i think teh intake would be sufficient to 6000rpm or even more with a little porting...i was gonna use trickflow 6.500" pushrods with the comp cam and p heads...you guys think i can still be able to use these rods??? i read that on most heads with 2.02 valves , you would need to fly cut the pistons or replace pistons but that on these you dont have to with most performance cams....with my lift being high and all, would i need to flycut or replace my pistons????
Grn92LX
Fidanza Man!
6,819
64
129
New York
Sep 30, 2004
#10
  • Sep 30, 2004
  • #10
No, you can NOT use those pushrods. 6.7" should be fine, but never hurts to measure. The rpm is the better choice for what you listed you want, but the performer is good as well. That cam should fit fine, but again, never hurts to check. Peak lift is nothing as the piston is at the bottom of the bore (i believe) when that occurs. I HIGHLY recommend a valve spring swap if you use the TW heads or just use the track heats.
9
96darkhorse
693
Oct 1, 2004
#11
  • Oct 1, 2004
  • #11
if i go with the perfomer, which i already have, will i be losing power over the rpm or will the power band and peak power be lower/higher?
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 1, 2004
#12
  • Oct 1, 2004
  • #12
You probably wouldnt make as much upstairs since you had originally said you wanted to make power to 6200. I think youi'll peak at 5500 with the performer. If you already have it, I dunno if its cost effective to swap to an rpm then.
9
96darkhorse
693
Oct 1, 2004
#13
  • Oct 1, 2004
  • #13
i guess it would be more beneficial switching to an rpm upper.....i wonder if anybody would wanna swap for an rpm upper?...i was gonna go with 373s but since ill be breathing and making more up top with an aluminum head, 410s would be the better choice..what size throttle body would be beneficial with this setup? 70 or 75mm??
chefster
426
michigan
Oct 1, 2004
#14
  • Oct 1, 2004
  • #14
how much for aluminum heads
Black95GTS
1,644
Marlborough, MA
Oct 1, 2004
#15
  • Oct 1, 2004
  • #15
75mm TB, no doubt. You're gonna have to port the eddie performer or RPM though, they are setup for 70 off the rack.
I would look into the new eddie heads as well. They are around 1G and flow extremely well. I've only heard good things about them.
9
96darkhorse
693
Oct 2, 2004
#16
  • Oct 2, 2004
  • #16
ttt
Joes95GT
3,132
Delaware
Oct 2, 2004
#17
  • Oct 2, 2004
  • #17
Good thinking.
Use Canfields....
Joe
9
96darkhorse
693
Oct 2, 2004
#18
  • Oct 2, 2004
  • #18
how much are canfields and how well do they flow compared afr,tw, edel, etc.
9
96darkhorse
693
Oct 3, 2004
#19
  • Oct 3, 2004
  • #19
anybody know where is the best place to get some track heats?? and anybody know where i can get a summit coupon???
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
limp
