well rebuild underway
MyBloodRunsBlue
127
alright so here is the spill...i have recently had a problem with the piston coming up and slapping the spark plug in cylinder number 2 so we have decided to rebuild it...
1. using stock block getting it machined...
2. buying manley rods and pistons along with an eagle crank as well as all the rings, etc...
3. getting houston performance s292 cam
4. 60 lb injectors
5. 8 rib setup
i already have a focus fuel pump with kb bap...do you think that will be suffice??
also what type of power do you think that will push? i'm hoping to boost around 13-14 lbs
